RTEMS 6.1
_lpi2c_slave_config Struct Reference
Structure with settings to initialize the LPI2C slave module. More...
#include <fsl_lpi2c.h>
bool enableSlave
uint8_t address0
uint8_t address1
lpi2c_slave_address_match_t addressMatchMode
bool filterDozeEnable
bool filterEnable
bool enableGeneralCall
struct {
   bool   _lpi2c_slave_config::enableAck
   bool   _lpi2c_slave_config::enableTx
   bool   _lpi2c_slave_config::enableRx
   bool   _lpi2c_slave_config::enableAddress
sclStall
bool ignoreAck
bool enableReceivedAddressRead
uint32_t sdaGlitchFilterWidth_ns
uint32_t sclGlitchFilterWidth_ns
uint32_t dataValidDelay_ns
uint32_t clockHoldTime_ns
This structure holds configuration settings for the LPI2C slave peripheral. To initialize this structure to reasonable defaults, call the LPI2C_SlaveGetDefaultConfig() function and pass a pointer to your configuration structure instance.
The configuration structure can be made constant so it resides in flash.
