RTEMS 6.1
MIPI DSI controller DPI interface configuration. More...
#include <fsl_mipi_dsi.h>
Data Fields | |
| uint16_t | pixelPayloadSize |
| dsi_dpi_color_coding_t | dpiColorCoding |
| dsi_dpi_pixel_packet_t | pixelPacket |
| dsi_dpi_video_mode_t | videoMode |
| dsi_dpi_bllp_mode_t | bllpMode |
| uint8_t | polarityFlags |
| uint16_t | hfp |
| uint16_t | hbp |
| uint16_t | hsw |
| uint8_t | vfp |
| uint8_t | vbp |
| uint16_t | panelHeight |
| uint8_t | virtualChannel |
| dsi_dpi_bllp_mode_t _dsi_dpi_config::bllpMode |
Behavior in BLLP.
| dsi_dpi_color_coding_t _dsi_dpi_config::dpiColorCoding |
DPI color coding.
| uint16_t _dsi_dpi_config::hbp |
Horizontal back porch, in dpi pixel clock.
| uint16_t _dsi_dpi_config::hfp |
Horizontal front porch, in dpi pixel clock.
| uint16_t _dsi_dpi_config::hsw |
Horizontal sync width, in dpi pixel clock.
| uint16_t _dsi_dpi_config::panelHeight |
Line number in vertical active area.
| dsi_dpi_pixel_packet_t _dsi_dpi_config::pixelPacket |
Pixel packet format.
| uint16_t _dsi_dpi_config::pixelPayloadSize |
Maximum number of pixels that should be sent as one DSI packet. Recommended that the line size (in pixels) is evenly divisible by this parameter.
| uint8_t _dsi_dpi_config::polarityFlags |
OR'ed value of _dsi_dpi_polarity_flag controls signal polarity.
| uint8_t _dsi_dpi_config::vbp |
Number of lines in vertical back porch.
| uint8_t _dsi_dpi_config::vfp |
Number of lines in vertical front porch.
| dsi_dpi_video_mode_t _dsi_dpi_config::videoMode |
Video mode.
| uint8_t _dsi_dpi_config::virtualChannel |
Virtual channel.
