RTEMS 6.1
_clock_video_pll_config Struct Reference
PLL configuration for AUDIO and VIDEO. More...
#include <fsl_clock.h>
uint8_t loopDivider
uint8_t postDivider
uint32_t numerator
uint32_t denominator
uint8_t src
Field Documentation
◆ denominator
uint32_t _clock_video_pll_config::denominator
30 bit denominator of fractional loop divider
◆ loopDivider
uint8_t _clock_video_pll_config::loopDivider
PLL loop divider. Valid range for DIV_SELECT divider value: 27~54.
◆ numerator
uint32_t _clock_video_pll_config::numerator
30 bit numerator of fractional loop divider.
◆ postDivider
uint8_t _clock_video_pll_config::postDivider
Divider after the PLL, should only be 1, 2, 4, 8, 16.
◆ src
uint8_t _clock_video_pll_config::src
Pll clock source, reference _clock_pll_clk_src
