RTEMS 6.1
_clock_sys_pll_config Struct Reference
PLL configuration for System. More...
#include <fsl_clock.h>
uint8_t loopDivider
uint32_t numerator
uint32_t denominator
uint8_t src
uint16_t ss_stop
uint8_t ss_enable
uint16_t ss_step
Field Documentation
◆ denominator
uint32_t _clock_sys_pll_config::denominator
30 bit denominator of fractional loop divider
◆ loopDivider
uint8_t _clock_sys_pll_config::loopDivider
PLL loop divider. Intended to be 1 (528M). 0 - Fout=Fref*20; 1 - Fout=Fref*22
◆ numerator
uint32_t _clock_sys_pll_config::numerator
30 bit numerator of fractional loop divider.
◆ src
uint8_t _clock_sys_pll_config::src
Pll clock source, reference _clock_pll_clk_src
◆ ss_enable
uint8_t _clock_sys_pll_config::ss_enable
Enable spread spectrum modulation
◆ ss_step
uint16_t _clock_sys_pll_config::ss_step
Step value to get frequency change step.
◆ ss_stop
uint16_t _clock_sys_pll_config::ss_stop
Stop value to get frequency change.
