RTEMS 6.1
#include <MIMXRT1052.h>
Data Fields | |
| uint8_t | RESERVED_0 [336] |
| __IO uint32_t | MISC0 |
| __IO uint32_t | MISC0_SET |
| __IO uint32_t | MISC0_CLR |
| __IO uint32_t | MISC0_TOG |
| uint8_t | RESERVED_1 [272] |
| __IO uint32_t | LOWPWR_CTRL |
| __IO uint32_t | LOWPWR_CTRL_SET |
| __IO uint32_t | LOWPWR_CTRL_CLR |
| __IO uint32_t | LOWPWR_CTRL_TOG |
| uint8_t | RESERVED_2 [32] |
| __IO uint32_t | OSC_CONFIG0 |
| __IO uint32_t | OSC_CONFIG0_SET |
| __IO uint32_t | OSC_CONFIG0_CLR |
| __IO uint32_t | OSC_CONFIG0_TOG |
| __IO uint32_t | OSC_CONFIG1 |
| __IO uint32_t | OSC_CONFIG1_SET |
| __IO uint32_t | OSC_CONFIG1_CLR |
| __IO uint32_t | OSC_CONFIG1_TOG |
| __IO uint32_t | OSC_CONFIG2 |
| __IO uint32_t | OSC_CONFIG2_SET |
| __IO uint32_t | OSC_CONFIG2_CLR |
| __IO uint32_t | OSC_CONFIG2_TOG |
XTALOSC24M - Register Layout Typedef
