RTEMS 6.1
Window WATCHDOG. More...
#include <stm32h723xx.h>
__IO uint32_t CR
__IO uint32_t CFR
__IO uint32_t SR
Window WATCHDOG.
Field Documentation
◆ CFR
__IO uint32_t WWDG_TypeDef::CFR
WWDG Configuration register, Address offset: 0x04
◆ CR
__IO uint32_t WWDG_TypeDef::CR
WWDG Control register, Address offset: 0x00
◆ SR
__IO uint32_t WWDG_TypeDef::SR
WWDG Status register, Address offset: 0x08
The documentation for this struct was generated from the following files:
