RTEMS 6.1
#include <MIMXRT1166_cm4.h>
struct {
   __IO uint32_t   VIDEO_MUX_Type::RW
   __IO uint32_t   VIDEO_MUX_Type::SET
   __IO uint32_t   VIDEO_MUX_Type::CLR
   __IO uint32_t   VIDEO_MUX_Type::TOG
VID_MUX_CTRL
uint8_t RESERVED_0 [16]
struct {
PLM_CTRL
struct {
YUV420_CTRL
uint8_t RESERVED_1 [16]
struct {
CFG_DT_DISABLE
uint8_t RESERVED_2 [16]
struct {
MIPI_DSI_CTRL
struct {
VID_MUX_CTRL
struct {
PLM_CTRL
struct {
YUV420_CTRL
struct {
CFG_DT_DISABLE
struct {
MIPI_DSI_CTRL
VIDEO_MUX - Register Layout Typedef
The documentation for this struct was generated from the following files:
