RTEMS 6.1
USB_OTG_OUT_Endpoint-Specific_Registers. More...
#include <stm32h723xx.h>
__IO uint32_t DOEPCTL
uint32_t Reserved04
__IO uint32_t DOEPINT
uint32_t Reserved0C
__IO uint32_t DOEPTSIZ
__IO uint32_t DOEPDMA
uint32_t Reserved18 [2]
Field Documentation
◆ DOEPCTL
__IO uint32_t USB_OTG_OUTEndpointTypeDef::DOEPCTL
dev OUT Endpoint Control Reg B00h + (ep_num * 20h) + 00h
◆ DOEPDMA
__IO uint32_t USB_OTG_OUTEndpointTypeDef::DOEPDMA
dev OUT Endpoint DMA Address B00h + (ep_num * 20h) + 14h
◆ DOEPINT
__IO uint32_t USB_OTG_OUTEndpointTypeDef::DOEPINT
dev OUT Endpoint Itr Reg B00h + (ep_num * 20h) + 08h
◆ DOEPTSIZ
__IO uint32_t USB_OTG_OUTEndpointTypeDef::DOEPTSIZ
dev OUT Endpoint Txfer Size B00h + (ep_num * 20h) + 10h
◆ Reserved04
uint32_t USB_OTG_OUTEndpointTypeDef::Reserved04
Reserved B00h + (ep_num * 20h) + 04h
◆ Reserved0C
uint32_t USB_OTG_OUTEndpointTypeDef::Reserved0C
Reserved B00h + (ep_num * 20h) + 0Ch
◆ Reserved18
uint32_t USB_OTG_OUTEndpointTypeDef::Reserved18
Reserved B00h + (ep_num * 20h) + 18h - B00h + (ep_num * 20h) + 1Ch
The documentation for this struct was generated from the following files:
