RTEMS 6.1
USB_OTG_IN_Endpoint-Specific_Register. More...
#include <stm32h723xx.h>
__IO uint32_t DIEPCTL
uint32_t Reserved04
__IO uint32_t DIEPINT
uint32_t Reserved0C
__IO uint32_t DIEPTSIZ
__IO uint32_t DIEPDMA
__IO uint32_t DTXFSTS
uint32_t Reserved18
Field Documentation
◆ DIEPCTL
__IO uint32_t USB_OTG_INEndpointTypeDef::DIEPCTL
dev IN Endpoint Control Reg 900h + (ep_num * 20h) + 00h
◆ DIEPDMA
__IO uint32_t USB_OTG_INEndpointTypeDef::DIEPDMA
IN Endpoint DMA Address Reg 900h + (ep_num * 20h) + 14h
◆ DIEPINT
__IO uint32_t USB_OTG_INEndpointTypeDef::DIEPINT
dev IN Endpoint Itr Reg 900h + (ep_num * 20h) + 08h
◆ DIEPTSIZ
__IO uint32_t USB_OTG_INEndpointTypeDef::DIEPTSIZ
IN Endpoint Txfer Size 900h + (ep_num * 20h) + 10h
◆ DTXFSTS
__IO uint32_t USB_OTG_INEndpointTypeDef::DTXFSTS
IN Endpoint Tx FIFO Status Reg 900h + (ep_num * 20h) + 18h
◆ Reserved04
uint32_t USB_OTG_INEndpointTypeDef::Reserved04
Reserved 900h + (ep_num * 20h) + 04h
◆ Reserved0C
uint32_t USB_OTG_INEndpointTypeDef::Reserved0C
Reserved 900h + (ep_num * 20h) + 0Ch
◆ Reserved18
uint32_t USB_OTG_INEndpointTypeDef::Reserved18
Reserved 900h+(ep_num*20h)+1Ch-900h+ (ep_num * 20h) + 1Ch
The documentation for this struct was generated from the following files:
