RTEMS 6.1
#include <MIMXRT1052.h>
uint8_t RESERVED_0 [416]
struct {
   __IO uint32_t   USB_ANALOG_Type::VBUS_DETECT
   __IO uint32_t   USB_ANALOG_Type::VBUS_DETECT_SET
   __IO uint32_t   USB_ANALOG_Type::VBUS_DETECT_CLR
   __IO uint32_t   USB_ANALOG_Type::VBUS_DETECT_TOG
   __IO uint32_t   USB_ANALOG_Type::CHRG_DETECT
   __IO uint32_t   USB_ANALOG_Type::CHRG_DETECT_SET
   __IO uint32_t   USB_ANALOG_Type::CHRG_DETECT_CLR
   __IO uint32_t   USB_ANALOG_Type::CHRG_DETECT_TOG
   __I uint32_t   USB_ANALOG_Type::VBUS_DETECT_STAT
   uint8_t   RESERVED_0 [12]
   __I uint32_t   USB_ANALOG_Type::CHRG_DETECT_STAT
   uint8_t   RESERVED_1 [12]
   __IO uint32_t   USB_ANALOG_Type::LOOPBACK
   __IO uint32_t   USB_ANALOG_Type::LOOPBACK_SET
   __IO uint32_t   USB_ANALOG_Type::LOOPBACK_CLR
   __IO uint32_t   USB_ANALOG_Type::LOOPBACK_TOG
   __IO uint32_t   USB_ANALOG_Type::MISC
   __IO uint32_t   USB_ANALOG_Type::MISC_SET
   __IO uint32_t   USB_ANALOG_Type::MISC_CLR
   __IO uint32_t   USB_ANALOG_Type::MISC_TOG
INSTANCE [2]
__I uint32_t DIGPROG
USB_ANALOG - Register Layout Typedef
