RTEMS
6.1
USBPHY_Type Struct Reference
Mapping Information
Iomuxc_pads
Device Peripheral Access Layer
USBPHY Peripheral Access Layer
MIMXRT1052.h
__IO
uint32_t
PWD
__IO
uint32_t
PWD_SET
__IO
uint32_t
PWD_CLR
__IO
uint32_t
PWD_TOG
__IO
uint32_t
TX
__IO
uint32_t
TX_SET
__IO
uint32_t
TX_CLR
__IO
uint32_t
TX_TOG
__IO
uint32_t
RX
__IO
uint32_t
RX_SET
__IO
uint32_t
RX_CLR
__IO
uint32_t
RX_TOG
__IO
uint32_t
CTRL
__IO
uint32_t
CTRL_SET
__IO
uint32_t
CTRL_CLR
__IO
uint32_t
CTRL_TOG
__IO
uint32_t
STATUS
uint8_t
RESERVED_0
[12]
__IO
uint32_t
DEBUGr
__IO
uint32_t
DEBUG_SET
__IO
uint32_t
DEBUG_CLR
__IO
uint32_t
DEBUG_TOG
__I
uint32_t
DEBUG0_STATUS
uint8_t
RESERVED_1
[12]
__IO
uint32_t
DEBUG1
__IO
uint32_t
DEBUG1_SET
__IO
uint32_t
DEBUG1_CLR
__IO
uint32_t
DEBUG1_TOG
__I
uint32_t
VERSION
uint8_t
RESERVED_2
[28]
__IO
uint32_t
PLL_SIC
__IO
uint32_t
PLL_SIC_SET
__IO
uint32_t
PLL_SIC_CLR
__IO
uint32_t
PLL_SIC_TOG
uint8_t
RESERVED_3
[16]
__IO
uint32_t
USB1_VBUS_DETECT
__IO
uint32_t
USB1_VBUS_DETECT_SET
__IO
uint32_t
USB1_VBUS_DETECT_CLR
__IO
uint32_t
USB1_VBUS_DETECT_TOG
__I
uint32_t
USB1_VBUS_DET_STAT
uint8_t
RESERVED_4
[12]
__IO
uint32_t
USB1_CHRG_DETECT
__IO
uint32_t
USB1_CHRG_DETECT_SET
__IO
uint32_t
USB1_CHRG_DETECT_CLR
__IO
uint32_t
USB1_CHRG_DETECT_TOG
__I
uint32_t
USB1_CHRG_DET_STAT
uint8_t
RESERVED_5
[12]
__IO
uint32_t
ANACTRL
__IO
uint32_t
ANACTRL_SET
__IO
uint32_t
ANACTRL_CLR
__IO
uint32_t
ANACTRL_TOG
__IO
uint32_t
USB1_LOOPBACK
__IO
uint32_t
USB1_LOOPBACK_SET
__IO
uint32_t
USB1_LOOPBACK_CLR
__IO
uint32_t
USB1_LOOPBACK_TOG
__IO
uint32_t
USB1_LOOPBACK_HSFSCNT
__IO
uint32_t
USB1_LOOPBACK_HSFSCNT_SET
__IO
uint32_t
USB1_LOOPBACK_HSFSCNT_CLR
__IO
uint32_t
USB1_LOOPBACK_HSFSCNT_TOG
__IO
uint32_t
TRIM_OVERRIDE_EN
__IO
uint32_t
TRIM_OVERRIDE_EN_SET
__IO
uint32_t
TRIM_OVERRIDE_EN_CLR
__IO
uint32_t
TRIM_OVERRIDE_EN_TOG
USBPHY - Register Layout Typedef
The documentation for this struct was generated from the following files:
bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/
MIMXRT1052.h
bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/
MIMXRT1166_cm4.h
MIMXRT1166_cm7.h
