RTEMS 6.1
UART_WakeUpTypeDef Struct Reference
UART wake up from stop mode parameters. More...
#include <stm32h7xx_hal_uart_ex.h>
uint32_t WakeUpEvent
uint16_t AddressLength
uint8_t Address
Field Documentation
◆ Address
uint8_t UART_WakeUpTypeDef::Address
UART/USART node address (7-bit long max).
◆ AddressLength
uint16_t UART_WakeUpTypeDef::AddressLength
Specifies whether the address is 4 or 7-bit long. This parameter can be a value of UARTEx WakeUp Address Length.
◆ WakeUpEvent
uint32_t UART_WakeUpTypeDef::WakeUpEvent
Specifies which event will activate the Wakeup from Stop mode flag (WUF). This parameter can be a value of UART WakeUp From Stop Selection. If set to UART_WAKEUP_ON_ADDRESS, the two other fields below must be filled up.
