RTEMS 6.1
UART Init Structure definition. More...
#include <stm32h7xx_hal_uart.h>
uint32_t BaudRate
uint32_t WordLength
uint32_t StopBits
uint32_t Parity
uint32_t Mode
uint32_t HwFlowCtl
uint32_t OverSampling
uint32_t OneBitSampling
uint32_t ClockPrescaler
Field Documentation
◆ BaudRate
uint32_t UART_InitTypeDef::BaudRate
This member configures the UART communication baud rate. The baud rate register is computed using the following formula:
LPUART:
Baud Rate Register = ((256 * lpuart_ker_ckpres) / ((huart->Init.BaudRate))) where lpuart_ker_ck_pres is the UART input clock divided by a prescaler
UART:
  • If oversampling is 16 or in LIN mode, Baud Rate Register = ((uart_ker_ckpres) / ((huart->Init.BaudRate)))
  • If oversampling is 8, Baud Rate Register[15:4] = ((2 * uart_ker_ckpres) / ((huart->Init.BaudRate)))[15:4] Baud Rate Register[3] = 0 Baud Rate Register[2:0] = (((2 * uart_ker_ckpres) / ((huart->Init.BaudRate)))[3:0]) >> 1 where uart_ker_ck_pres is the UART input clock divided by a prescaler
◆ ClockPrescaler
uint32_t UART_InitTypeDef::ClockPrescaler
Specifies the prescaler value used to divide the UART clock source. This parameter can be a value of UART Clock Prescaler.
◆ HwFlowCtl
uint32_t UART_InitTypeDef::HwFlowCtl
Specifies whether the hardware flow control mode is enabled or disabled. This parameter can be a value of UART Hardware Flow Control.
◆ Mode
uint32_t UART_InitTypeDef::Mode
Specifies whether the Receive or Transmit mode is enabled or disabled. This parameter can be a value of UART Transfer Mode.
◆ OneBitSampling
uint32_t UART_InitTypeDef::OneBitSampling
Specifies whether a single sample or three samples' majority vote is selected. Selecting the single sample method increases the receiver tolerance to clock deviations. This parameter can be a value of UART One Bit Sampling Method.
◆ OverSampling
uint32_t UART_InitTypeDef::OverSampling
Specifies whether the Over sampling 8 is enabled or disabled, to achieve higher speed (up to f_PCLK/8). This parameter can be a value of UART Over Sampling.
◆ Parity
uint32_t UART_InitTypeDef::Parity
Specifies the parity mode. This parameter can be a value of UART Parity
Note
When parity is enabled, the computed parity is inserted at the MSB position of the transmitted data (9th bit when the word length is set to 9 data bits; 8th bit when the word length is set to 8 data bits).
◆ StopBits
uint32_t UART_InitTypeDef::StopBits
Specifies the number of stop bits transmitted. This parameter can be a value of UART Number of Stop Bits.
◆ WordLength
uint32_t UART_InitTypeDef::WordLength
Specifies the number of data bits transmitted or received in a frame. This parameter can be a value of UARTEx Word Length.
