RTEMS 6.1
UART Advanced Features initialization structure definition. More...
#include <stm32h7xx_hal_uart.h>
uint32_t AdvFeatureInit
uint32_t TxPinLevelInvert
uint32_t RxPinLevelInvert
uint32_t DataInvert
uint32_t Swap
uint32_t OverrunDisable
uint32_t DMADisableonRxError
uint32_t AutoBaudRateEnable
uint32_t AutoBaudRateMode
uint32_t MSBFirst
Field Documentation
◆ AdvFeatureInit
uint32_t UART_AdvFeatureInitTypeDef::AdvFeatureInit
Specifies which advanced UART features is initialized. Several Advanced Features may be initialized at the same time . This parameter can be a value of UART Advanced Feature Initialization Type.
◆ AutoBaudRateEnable
uint32_t UART_AdvFeatureInitTypeDef::AutoBaudRateEnable
Specifies whether auto Baud rate detection is enabled. This parameter can be a value of UART Advanced Feature Auto BaudRate Enable.
◆ AutoBaudRateMode
uint32_t UART_AdvFeatureInitTypeDef::AutoBaudRateMode
If auto Baud rate detection is enabled, specifies how the rate detection is carried out. This parameter can be a value of UART Advanced Feature AutoBaud Rate Mode.
◆ DataInvert
uint32_t UART_AdvFeatureInitTypeDef::DataInvert
Specifies whether data are inverted (positive/direct logic vs negative/inverted logic). This parameter can be a value of UART Advanced Feature Binary Data Inversion.
◆ DMADisableonRxError
uint32_t UART_AdvFeatureInitTypeDef::DMADisableonRxError
Specifies whether the DMA is disabled in case of reception error. This parameter can be a value of UART Advanced Feature DMA Disable On Rx Error.
◆ MSBFirst
uint32_t UART_AdvFeatureInitTypeDef::MSBFirst
Specifies whether MSB is sent first on UART line. This parameter can be a value of UART Advanced Feature MSB First.
◆ OverrunDisable
uint32_t UART_AdvFeatureInitTypeDef::OverrunDisable
Specifies whether the reception overrun detection is disabled. This parameter can be a value of UART Advanced Feature Overrun Disable.
◆ RxPinLevelInvert
uint32_t UART_AdvFeatureInitTypeDef::RxPinLevelInvert
Specifies whether the RX pin active level is inverted. This parameter can be a value of UART Advanced Feature RX Pin Active Level Inversion.
◆ Swap
uint32_t UART_AdvFeatureInitTypeDef::Swap
Specifies whether TX and RX pins are swapped. This parameter can be a value of UART Advanced Feature RX TX Pins Swap.
◆ TxPinLevelInvert
uint32_t UART_AdvFeatureInitTypeDef::TxPinLevelInvert
Specifies whether the TX pin active level is inverted. This parameter can be a value of UART Advanced Feature TX Pin Active Level Inversion.
