RTEMS 6.1
Thread_Start_information Struct Reference
#include <thread.h>
Thread_Entry_information Entry
bool is_preemptible
const Thread_CPU_budget_operationscpu_budget_operations
 This member may provide the CPU budget operations activated when a thread is initialized before it is started or restarted.
uint32_t isr_level
Priority_Control initial_priority
void(* stack_free )(void *)
 This field points to the handler which should free the stack.
Stack_Control Initial_stack
Context_Control_fpfp_context
void * tls_area
The following structure contains the information which defines the starting state of a thread.
Field Documentation
◆ Entry
Thread_Entry_information Thread_Start_information::Entry
This field contains the thread entry information.
◆ fp_context
Context_Control_fp* Thread_Start_information::fp_context
This field is the initial FP context area address.
◆ initial_priority
Priority_Control Thread_Start_information::initial_priority
This field is the initial priority.
◆ Initial_stack
Stack_Control Thread_Start_information::Initial_stack
This field is the stack information.
◆ is_preemptible
bool Thread_Start_information::is_preemptible
This field indicates whether the thread was preemptible when it started.
◆ isr_level
uint32_t Thread_Start_information::isr_level
This field is the initial ISR disable level of this thread.
◆ tls_area
void* Thread_Start_information::tls_area
The thread-local storage (TLS) area
