RTEMS 6.1
TTFD Controller Area Network. More...
#include <stm32h723xx.h>
__IO uint32_t TTTMC
__IO uint32_t TTRMC
__IO uint32_t TTOCF
__IO uint32_t TTMLM
__IO uint32_t TURCF
__IO uint32_t TTOCN
__IO uint32_t TTGTP
__IO uint32_t TTTMK
__IO uint32_t TTIR
__IO uint32_t TTIE
__IO uint32_t TTILS
__IO uint32_t TTOST
__IO uint32_t TURNA
__IO uint32_t TTLGT
__IO uint32_t TTCTC
__IO uint32_t TTCPT
__IO uint32_t TTCSM
__IO uint32_t RESERVED1 [111]
__IO uint32_t TTTS
Field Documentation
◆ RESERVED1
__IO uint32_t TTCAN_TypeDef::RESERVED1
Reserved, 0x144 - 0x2FC
◆ TTCPT
__IO uint32_t TTCAN_TypeDef::TTCPT
TT Capture Time register, Address offset: 0x13C
◆ TTCSM
__IO uint32_t TTCAN_TypeDef::TTCSM
TT Cycle Sync Mark register, Address offset: 0x140
◆ TTCTC
__IO uint32_t TTCAN_TypeDef::TTCTC
TT Cycle Time and Count register, Address offset: 0x138
◆ TTGTP
__IO uint32_t TTCAN_TypeDef::TTGTP
TT Global Time Preset register, Address offset: 0x118
◆ TTIE
__IO uint32_t TTCAN_TypeDef::TTIE
TT Interrupt Enable register, Address offset: 0x124
◆ TTILS
__IO uint32_t TTCAN_TypeDef::TTILS
TT Interrupt Line Select register, Address offset: 0x128
◆ TTIR
__IO uint32_t TTCAN_TypeDef::TTIR
TT Interrupt register, Address offset: 0x120
◆ TTLGT
__IO uint32_t TTCAN_TypeDef::TTLGT
TT Local and Global Time register, Address offset: 0x134
◆ TTMLM
__IO uint32_t TTCAN_TypeDef::TTMLM
TT Matrix Limits register, Address offset: 0x10C
◆ TTOCF
__IO uint32_t TTCAN_TypeDef::TTOCF
TT Operation Configuration register, Address offset: 0x108
◆ TTOCN
__IO uint32_t TTCAN_TypeDef::TTOCN
TT Operation Control register, Address offset: 0x114
◆ TTOST
__IO uint32_t TTCAN_TypeDef::TTOST
TT Operation Status register, Address offset: 0x12C
◆ TTRMC
__IO uint32_t TTCAN_TypeDef::TTRMC
TT Reference Message Configuration register, Address offset: 0x104
◆ TTTMC
__IO uint32_t TTCAN_TypeDef::TTTMC
TT Trigger Memory Configuration register, Address offset: 0x100
◆ TTTMK
__IO uint32_t TTCAN_TypeDef::TTTMK
TT Time Mark register, Address offset: 0x11C
◆ TTTS
__IO uint32_t TTCAN_TypeDef::TTTS
TT Trigger Select register, Address offset: 0x300
◆ TURCF
__IO uint32_t TTCAN_TypeDef::TURCF
TUR Configuration register, Address offset: 0x110
◆ TURNA
__IO uint32_t TTCAN_TypeDef::TURNA
TT TUR Numerator Actual register, Address offset: 0x130
The documentation for this struct was generated from the following files:
