RTEMS
6.1
TMR_Type Struct Reference
Mapping Information
Iomuxc_pads
Device Peripheral Access Layer
TMR Peripheral Access Layer
MIMXRT1052.h
struct {
__IO
uint16_t
TMR_Type::COMP1
__IO
uint16_t
TMR_Type::COMP2
__IO
uint16_t
TMR_Type::CAPT
__IO
uint16_t
TMR_Type::LOAD
__IO
uint16_t
TMR_Type::HOLD
__IO
uint16_t
TMR_Type::CNTR
__IO
uint16_t
TMR_Type::CTRL
__IO
uint16_t
TMR_Type::SCTRL
__IO
uint16_t
TMR_Type::CMPLD1
__IO
uint16_t
TMR_Type::CMPLD2
__IO
uint16_t
TMR_Type::CSCTRL
__IO
uint16_t
TMR_Type::FILT
__IO
uint16_t
TMR_Type::DMA
uint8_t
RESERVED_0
[4]
__IO
uint16_t
TMR_Type::ENBL
CHANNEL
[4]
struct {
__IO
uint16_t
TMR_Type::COMP1
__IO
uint16_t
TMR_Type::COMP2
__IO
uint16_t
TMR_Type::CAPT
__IO
uint16_t
TMR_Type::LOAD
__IO
uint16_t
TMR_Type::HOLD
__IO
uint16_t
TMR_Type::CNTR
__IO
uint16_t
TMR_Type::CTRL
__IO
uint16_t
TMR_Type::SCTRL
__IO
uint16_t
TMR_Type::CMPLD1
__IO
uint16_t
TMR_Type::CMPLD2
__IO
uint16_t
TMR_Type::CSCTRL
__IO
uint16_t
TMR_Type::FILT
__IO
uint16_t
TMR_Type::DMA
uint8_t
RESERVED_0
[4]
__IO
uint16_t
TMR_Type::ENBL
CHANNEL
[4]
struct {
__IO
uint16_t
TMR_Type::COMP1
__IO
uint16_t
TMR_Type::COMP2
__IO
uint16_t
TMR_Type::CAPT
__IO
uint16_t
TMR_Type::LOAD
__IO
uint16_t
TMR_Type::HOLD
__IO
uint16_t
TMR_Type::CNTR
__IO
uint16_t
TMR_Type::CTRL
__IO
uint16_t
TMR_Type::SCTRL
__IO
uint16_t
TMR_Type::CMPLD1
__IO
uint16_t
TMR_Type::CMPLD2
__IO
uint16_t
TMR_Type::CSCTRL
__IO
uint16_t
TMR_Type::FILT
__IO
uint16_t
TMR_Type::DMA
uint8_t
RESERVED_0
[4]
__IO
uint16_t
TMR_Type::ENBL
CHANNEL
[4]
TMR - Register Layout Typedef
The documentation for this struct was generated from the following files:
bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/
MIMXRT1052.h
bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/
MIMXRT1166_cm4.h
MIMXRT1166_cm7.h
