RTEMS 6.1
#include <MIMXRT1166_cm4.h>
Data Fields | |
| __IO uint32_t | CTRL0 |
| __IO uint32_t | CTRL0_SET |
| __IO uint32_t | CTRL0_CLR |
| __IO uint32_t | CTRL0_TOG |
| __IO uint32_t | CTRL1 |
| __IO uint32_t | CTRL1_SET |
| __IO uint32_t | CTRL1_CLR |
| __IO uint32_t | CTRL1_TOG |
| __IO uint32_t | RANGE0 |
| __IO uint32_t | RANGE0_SET |
| __IO uint32_t | RANGE0_CLR |
| __IO uint32_t | RANGE0_TOG |
| __IO uint32_t | RANGE1 |
| __IO uint32_t | RANGE1_SET |
| __IO uint32_t | RANGE1_CLR |
| __IO uint32_t | RANGE1_TOG |
| uint8_t | RESERVED_0 [16] |
| __IO uint32_t | STATUS0 |
TMPSNS - Register Layout Typedef
