RTEMS 6.1
TIM_HallSensor_InitTypeDef Struct Reference
TIM Hall sensor Configuration Structure definition. More...
#include <stm32h7xx_hal_tim_ex.h>
uint32_t IC1Polarity
uint32_t IC1Prescaler
uint32_t IC1Filter
uint32_t Commutation_Delay
Field Documentation
◆ Commutation_Delay
uint32_t TIM_HallSensor_InitTypeDef::Commutation_Delay
Specifies the pulse value to be loaded into the Capture Compare Register. This parameter can be a number between Min_Data = 0x0000 and Max_Data = 0xFFFF
◆ IC1Filter
uint32_t TIM_HallSensor_InitTypeDef::IC1Filter
Specifies the input capture filter. This parameter can be a number between Min_Data = 0x0 and Max_Data = 0xF
◆ IC1Polarity
uint32_t TIM_HallSensor_InitTypeDef::IC1Polarity
Specifies the active edge of the input signal. This parameter can be a value of TIM Input Capture Polarity
◆ IC1Prescaler
uint32_t TIM_HallSensor_InitTypeDef::IC1Prescaler
Specifies the Input Capture Prescaler. This parameter can be a value of TIM Input Capture Prescaler
