RTEMS 6.1
Tamper and backup registers. More...
#include <stm32h7a3xx.h>
Data Fields | |
| __IO uint32_t | CR1 |
| __IO uint32_t | CR2 |
| uint32_t | RESERVED0 |
| __IO uint32_t | FLTCR |
| __IO uint32_t | ATCR1 |
| __IO uint32_t | ATSEEDR |
| __IO uint32_t | ATOR |
| uint32_t | RESERVED1 [4] |
| __IO uint32_t | IER |
| __IO uint32_t | SR |
| __IO uint32_t | MISR |
| uint32_t | RESERVED2 |
| __IO uint32_t | SCR |
| __IO uint32_t | COUNTR |
| uint32_t | RESERVED3 [3] |
| __IO uint32_t | CFGR |
| uint32_t | RESERVED4 [43] |
| __IO uint32_t | BKP0R |
| __IO uint32_t | BKP1R |
| __IO uint32_t | BKP2R |
| __IO uint32_t | BKP3R |
| __IO uint32_t | BKP4R |
| __IO uint32_t | BKP5R |
| __IO uint32_t | BKP6R |
| __IO uint32_t | BKP7R |
| __IO uint32_t | BKP8R |
| __IO uint32_t | BKP9R |
| __IO uint32_t | BKP10R |
| __IO uint32_t | BKP11R |
| __IO uint32_t | BKP12R |
| __IO uint32_t | BKP13R |
| __IO uint32_t | BKP14R |
| __IO uint32_t | BKP15R |
| __IO uint32_t | BKP16R |
| __IO uint32_t | BKP17R |
| __IO uint32_t | BKP18R |
| __IO uint32_t | BKP19R |
| __IO uint32_t | BKP20R |
| __IO uint32_t | BKP21R |
| __IO uint32_t | BKP22R |
| __IO uint32_t | BKP23R |
| __IO uint32_t | BKP24R |
| __IO uint32_t | BKP25R |
| __IO uint32_t | BKP26R |
| __IO uint32_t | BKP27R |
| __IO uint32_t | BKP28R |
| __IO uint32_t | BKP29R |
| __IO uint32_t | BKP30R |
| __IO uint32_t | BKP31R |
| __IO uint32_t TAMP_TypeDef::ATCR1 |
TAMP active tamper control register, Address offset: 0x10
| __IO uint32_t TAMP_TypeDef::ATOR |
TAMP active tamper output register, Address offset: 0x18
| __IO uint32_t TAMP_TypeDef::ATSEEDR |
TAMP active tamper seed register, Address offset: 0x14
| __IO uint32_t TAMP_TypeDef::BKP0R |
TAMP backup register 0, Address offset: 0x100
| __IO uint32_t TAMP_TypeDef::BKP10R |
TAMP backup register 10, Address offset: 0x128
| __IO uint32_t TAMP_TypeDef::BKP11R |
TAMP backup register 11, Address offset: 0x12C
| __IO uint32_t TAMP_TypeDef::BKP12R |
TAMP backup register 12, Address offset: 0x130
| __IO uint32_t TAMP_TypeDef::BKP13R |
TAMP backup register 13, Address offset: 0x134
| __IO uint32_t TAMP_TypeDef::BKP14R |
TAMP backup register 14, Address offset: 0x138
| __IO uint32_t TAMP_TypeDef::BKP15R |
TAMP backup register 15, Address offset: 0x13C
| __IO uint32_t TAMP_TypeDef::BKP16R |
TAMP backup register 16, Address offset: 0x140
| __IO uint32_t TAMP_TypeDef::BKP17R |
TAMP backup register 17, Address offset: 0x144
| __IO uint32_t TAMP_TypeDef::BKP18R |
TAMP backup register 18, Address offset: 0x148
| __IO uint32_t TAMP_TypeDef::BKP19R |
TAMP backup register 19, Address offset: 0x14C
| __IO uint32_t TAMP_TypeDef::BKP1R |
TAMP backup register 1, Address offset: 0x104
| __IO uint32_t TAMP_TypeDef::BKP20R |
TAMP backup register 20, Address offset: 0x150
| __IO uint32_t TAMP_TypeDef::BKP21R |
TAMP backup register 21, Address offset: 0x154
| __IO uint32_t TAMP_TypeDef::BKP22R |
TAMP backup register 22, Address offset: 0x158
| __IO uint32_t TAMP_TypeDef::BKP23R |
TAMP backup register 23, Address offset: 0x15C
| __IO uint32_t TAMP_TypeDef::BKP24R |
TAMP backup register 24, Address offset: 0x160
| __IO uint32_t TAMP_TypeDef::BKP25R |
TAMP backup register 25, Address offset: 0x164
| __IO uint32_t TAMP_TypeDef::BKP26R |
TAMP backup register 26, Address offset: 0x168
| __IO uint32_t TAMP_TypeDef::BKP27R |
TAMP backup register 27, Address offset: 0x16C
| __IO uint32_t TAMP_TypeDef::BKP28R |
TAMP backup register 28, Address offset: 0x170
| __IO uint32_t TAMP_TypeDef::BKP29R |
TAMP backup register 29, Address offset: 0x174
| __IO uint32_t TAMP_TypeDef::BKP2R |
TAMP backup register 2, Address offset: 0x108
| __IO uint32_t TAMP_TypeDef::BKP30R |
TAMP backup register 30, Address offset: 0x178
| __IO uint32_t TAMP_TypeDef::BKP31R |
TAMP backup register 31, Address offset: 0x17C
| __IO uint32_t TAMP_TypeDef::BKP3R |
TAMP backup register 3, Address offset: 0x10C
| __IO uint32_t TAMP_TypeDef::BKP4R |
TAMP backup register 4, Address offset: 0x110
| __IO uint32_t TAMP_TypeDef::BKP5R |
TAMP backup register 5, Address offset: 0x114
| __IO uint32_t TAMP_TypeDef::BKP6R |
TAMP backup register 6, Address offset: 0x118
| __IO uint32_t TAMP_TypeDef::BKP7R |
TAMP backup register 7, Address offset: 0x11C
| __IO uint32_t TAMP_TypeDef::BKP8R |
TAMP backup register 8, Address offset: 0x120
| __IO uint32_t TAMP_TypeDef::BKP9R |
TAMP backup register 9, Address offset: 0x124
| __IO uint32_t TAMP_TypeDef::CFGR |
TAMP configuration register, Address offset: 0x50
| __IO uint32_t TAMP_TypeDef::COUNTR |
TAMP monotonic counter register, Address offset: 0x40
| __IO uint32_t TAMP_TypeDef::CR1 |
TAMP configuration register 1, Address offset: 0x00
| __IO uint32_t TAMP_TypeDef::CR2 |
TAMP configuration register 2, Address offset: 0x04
| __IO uint32_t TAMP_TypeDef::FLTCR |
TAMP filter control register, Address offset: 0x0C
| __IO uint32_t TAMP_TypeDef::IER |
TAMP interrupt enable register, Address offset: 0x2C
| __IO uint32_t TAMP_TypeDef::MISR |
TAMP masked interrupt status register, Address offset: 0x34
| uint32_t TAMP_TypeDef::RESERVED0 |
Reserved, Address offset: 0x08
| uint32_t TAMP_TypeDef::RESERVED1 |
Reserved, Address offset: 0x1C – 0x28
| uint32_t TAMP_TypeDef::RESERVED2 |
Reserved, Address offset: 0x38
| uint32_t TAMP_TypeDef::RESERVED3 |
Reserved, Address offset: 0x44 – 0x4C
| uint32_t TAMP_TypeDef::RESERVED4 |
Reserved, Address offset: 0x54 – 0xFC
| __IO uint32_t TAMP_TypeDef::SCR |
TAMP status clear register, Address offset: 0x3C
| __IO uint32_t TAMP_TypeDef::SR |
TAMP status register, Address offset: 0x30
