RTEMS 6.1
Test context for spec:/score/val/fatal test case. More...
Data Fields | |
| Atomic_Uint | counter |
| This member is a fatal extension invocation counter. | |
| rtems_fatal_source | source |
| This member contains the last fatal source. | |
| rtems_fatal_code | code |
| This member contains the last fatal code. | |
