RTEMS 6.1
Test context for spec:/score/tq/req/surrender-priority-inherit test case. More...
CallWithinISRRequest request
 This member contains the call within ISR request.
SMP_barrier_Control barrier
 This member contains the barrier to synchronize the runner and the worker.
bool inherited_priorities_are_dispensible
 If this member is true, then all priorities of the previous owner inherited from the thread queue thread shall be dispensable.
bool helping_schedules_are_dispensible
 If this member is true, then all helping schedulers of the previous owner thread gained through the thread queue shall be dispensable.
bool use_helping_scheduler
 If this member is true, then the previous owner thread shall use helping scheduler.
bool gains_new_priority
 If this member is true, then the new owner thread shall gain a vital priority.
bool gains_new_helping_scheduler
 If this member is true, then the new owner thread shall gain a vital helping scheduler.
bool suspended
 If this member is true, then the new owner thread shall be suspended.
bool intend_to_block
 If this member is true, then the new owner thread shall be in the intend to block wait state.
bool action_performed
 If this member is true, then the action was performed.
rtems_task_priority priority_before
 This member contains the current priority of the previous owner thread before the thread queue surrender operation.
rtems_task_priority priority_after
 This member contains the current priority of the previous owner thread after the thread queue surrender operation.
rtems_id previous_owner
 This member contains the identifier of the previous owner thread.
TQContexttq_ctx
 This member contains a copy of the corresponding ScoreTqReqSurrenderPriorityInherit_Run() parameter.
struct {
   size_t   pcs [8]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   ScoreTqReqSurrenderPriorityInherit_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
