RTEMS 6.1
Test context for spec:/score/tq/req/flush-priority test case. More...
CallWithinISRRequest request
 This member contains the call within ISR request.
TQContexttq_ctx
 This member contains a copy of the corresponding ScoreTqReqFlushPriority_Run() parameter.
bool supports_multiple_priority_queues
struct {
   size_t   pcs [1]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   ScoreTqReqFlushPriority_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
