RTEMS 6.1
Test context for spec:/score/tq/req/flush-priority-inherit test case. More...
CallWithinISRRequest request
 This member contains the call within ISR request.
bool minimum
 If this member is true, then a minimum priority of the owner of the thread queue shall be inherited from a thread enqueued on the thread queue.
TQContexttq_ctx
 This member contains a copy of the corresponding ScoreTqReqFlushPriorityInherit_Run() parameter.
struct {
   size_t   pci [2]
 This member defines the pre-condition indices for the next action.
   size_t   pcs [2]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   ScoreTqReqFlushPriorityInherit_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
