RTEMS 6.1
Test context for spec:/score/tq/req/enqueue-priority test case. More...
bool helping
 This this member is true, then the enqueueing thread shall have at least one helping scheduler.
rtems_task_priority priority
 This member specifies the priority of a thread with an eligible scheduler equal to an eligible scheduler of the enqueueing thread.
size_t other_before
 If this member is true, then a thread those eligible schedulers are ineligible scheduler to the enqueueing task should be enqueued before a thread with an eligible scheduler equal to an eligible scheduler of the enqueueing thread.
size_t other_after
 If this member is true, then a thread those eligible schedulers are ineligible scheduler to the enqueueing task should be enqueued after a thread with an eligible scheduler equal to an eligible scheduler of the enqueueing thread.
TQContexttq_ctx
 This member contains a copy of the corresponding ScoreTqReqEnqueuePriority_Run() parameter.
struct {
   size_t   pcs [3]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   ScoreTqReqEnqueuePriority_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
