RTEMS 6.1
Test context for spec:/score/tq/req/enqueue-mrsp test case. More...
bool helping
 This this member is true, then the enqueueing thread shall have at least one helping scheduler which is an ineligible scheduler for the already enqueued threads.
rtems_task_priority priority
 This member specifies the priority of an already enqueued thread with an eligible scheduler equal to an eligible scheduler of the enqueueing thread.
size_t other_before
 If this member is true, then a thread those eligible schedulers are ineligible scheduler to the enqueueing task should be enqueued before a thread with an eligible scheduler equal to an eligible scheduler of the enqueueing thread.
size_t other_after
 If this member is true, then a thread those eligible schedulers are ineligible scheduler to the enqueueing task should be enqueued after a thread with an eligible scheduler equal to an eligible scheduler of the enqueueing thread.
TQContexttq_ctx
 This member contains a copy of the corresponding ScoreTqReqEnqueueMrsp_Run() parameter.
struct {
   size_t   pcs [3]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   ScoreTqReqEnqueueMrsp_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
