RTEMS 6.1
Test context for spec:/score/tq/req/enqueue-ceiling test case. More...
Data Fields | |
| bool | helping |
| This this member is true, then the enqueueing thread shall have at least one helping scheduler. | |
| rtems_task_priority | priority |
| This member specifies the priority of a thread with an eligible scheduler equal to an eligible scheduler of the enqueueing thread. | |
| size_t | other_before |
| If this member is true, then a thread those eligible schedulers are ineligible scheduler to the enqueueing task should be enqueued before a thread with an eligible scheduler equal to an eligible scheduler of the enqueueing thread. | |
| size_t | other_after |
| If this member is true, then a thread those eligible schedulers are ineligible scheduler to the enqueueing task should be enqueued after a thread with an eligible scheduler equal to an eligible scheduler of the enqueueing thread. | |
| TQContext * | tq_ctx |
| This member contains a copy of the corresponding ScoreTqReqEnqueueCeiling_Run() parameter. | |
| struct { | |
| size_t pcs [3] | |
| This member defines the pre-condition states for the next action. | |
| bool in_action_loop | |
| If this member is true, then the test action loop is executed. | |
| size_t index | |
| This member contains the next transition map index. | |
| ScoreTqReqEnqueueCeiling_Entry entry | |
| This member contains the current transition map entry. | |
| bool skip | |
| If this member is true, then the current transition variant should be skipped. | |
| } | Map |
