RTEMS 6.1
Test context for spec:/score/thread/val/thread test case. More...
rtems_id worker_id
 This member contains the worker task identifier.
rtems_id killer_id
 This member contains the killer task identifier.
volatile double fp_obj
 This member contains a floating-point object.
int thread_switch_state
 This member indicates the thread switch state.
uintptr_t runner_stack [2]
 This member contain the runner stack pointer at the context switch.
uintptr_t worker_stack [2]
 This member contain the worker stack pointer at the context switch.
