RTEMS 6.1
Test context for spec:/score/smp/val/fatal-scheduler-requires-exactly-one-processor test case. More...
Data Fields | |
| rtems_fatal_source | source |
| This member contains a copy of the corresponding ScoreSmpValFatalSchedulerRequiresExactlyOneProcessor_Run() parameter. | |
| rtems_fatal_code | code |
