RTEMS 6.1
Test context for spec:/score/sem/req/surrender test case. More...
Data Fields | |
| uint32_t | count_before |
| This member specifies the semaphore count before the directive call. | |
| Status_Control | status |
| This member contains the return status of the directive call. | |
| uint32_t | count_after |
| This member contains the semaphore count after the directive call. | |
| bool | blocked |
| If this member is true, then there shall be threads blocked on the semaphore. | |
| TQSemContext * | tq_ctx |
| This member contains a copy of the corresponding ScoreSemReqSurrender_Run() parameter. | |
| struct { | |
| size_t pcs [3] | |
| This member defines the pre-condition states for the next action. | |
| bool in_action_loop | |
| If this member is true, then the test action loop is executed. | |
| size_t index | |
| This member contains the next transition map index. | |
| ScoreSemReqSurrender_Entry entry | |
| This member contains the current transition map entry. | |
| bool skip | |
| If this member is true, then the current transition variant should be skipped. | |
| } | Map |
