RTEMS 6.1
Test context for spec:/score/sched/req/yield test case. More...
Data Fields | |
| TQContext | tq_ctx |
| This member contains the thread queue test context. | |
| rtems_id | sticky_mutex |
| This member contains the identifier of a sticky mutex. | |
| uint32_t | cpu_after_yield |
| This member contains the processor index after yielding. | |
| bool | has_helping |
| If this member is true, then the runner shall have a helping scheduler. | |
| bool | use_helping |
| If this member is true, then the runner shall use a helping scheduler. | |
| bool | ready |
| If this member is true, then the runner shall be ready in its home scheduler. | |
| bool | sticky |
| If this member is true, then the runner shall be sticky. | |
| bool | other_ready |
| If this member is true, then another ready task in the home scheduler of the runner shall be ready with an equal priority. | |
| bool | is_idle_before_yield |
| If this member is true, then the processor zero was idle before yielding. | |
| bool | is_idle_after_yield |
| If this member is true, then the processor zero was idle after yielding. | |
| struct { | |
| size_t pcs [5] | |
| This member defines the pre-condition states for the next action. | |
| bool in_action_loop | |
| If this member is true, then the test action loop is executed. | |
| size_t index | |
| This member contains the next transition map index. | |
| ScoreSchedReqYield_Entry entry | |
| This member contains the current transition map entry. | |
| bool skip | |
| If this member is true, then the current transition variant should be skipped. | |
| } | Map |
