RTEMS 6.1
Test context for spec:/score/mtx/req/seize-wait test case. More...
bool owner_caller
 If this member is true, then the calling thread shall be the owner of the mutex.
bool owner_other
 If this member is true, then a thread other than the calling thread shall be the owner of the mutex.
bool deadlock
 If this member is true, then a deadlock shall occur.
rtems_task_priority priority_before
 This member contains the current priority of the calling thread before the directive call.
const rtems_tcbowner_after
 This member contains the owner of the mutex after the directive call.
rtems_task_priority priority_after
 This member contains the current priority of the calling thread after the directive call.
TQMtxContexttq_ctx
 This member contains a copy of the corresponding ScoreMtxReqSeizeWait_Run() parameter.
struct {
   size_t   pci [6]
 This member defines the pre-condition indices for the next action.
   size_t   pcs [6]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   ScoreMtxReqSeizeWait_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
