RTEMS 6.1
System configuration controller. More...
#include <stm32h723xx.h>
Data Fields | |
| uint32_t | RESERVED1 |
| __IO uint32_t | PMCR |
| __IO uint32_t | EXTICR [4] |
| __IO uint32_t | CFGR |
| uint32_t | RESERVED2 |
| __IO uint32_t | CCCSR |
| __IO uint32_t | CCVR |
| __IO uint32_t | CCCR |
| uint32_t | RESERVED3 |
| __IO uint32_t | ADC2ALT |
| uint32_t | RESERVED4 [60] |
| __IO uint32_t | PKGR |
| uint32_t | RESERVED5 [118] |
| __IO uint32_t | UR0 |
| __IO uint32_t | UR1 |
| __IO uint32_t | UR2 |
| __IO uint32_t | UR3 |
| __IO uint32_t | UR4 |
| __IO uint32_t | UR5 |
| __IO uint32_t | UR6 |
| __IO uint32_t | UR7 |
| uint32_t | RESERVED6 [3] |
| __IO uint32_t | UR11 |
| __IO uint32_t | UR12 |
| __IO uint32_t | UR13 |
| __IO uint32_t | UR14 |
| __IO uint32_t | UR15 |
| __IO uint32_t | UR16 |
| __IO uint32_t | UR17 |
| __IO uint32_t | UR18 |
| __IO uint32_t | PWRCR |
| __IO uint32_t | UR8 |
| __IO uint32_t | UR9 |
| __IO uint32_t | UR10 |
| __IO uint32_t SYSCFG_TypeDef::ADC2ALT |
ADC2 internal input alternate connection register, Address offset: 0x30
| __IO uint32_t SYSCFG_TypeDef::CCCR |
SYSCFG compensation cell code register, Address offset: 0x28
| __IO uint32_t SYSCFG_TypeDef::CCCSR |
SYSCFG compensation cell control/status register, Address offset: 0x20
| __IO uint32_t SYSCFG_TypeDef::CCVR |
SYSCFG compensation cell value register, Address offset: 0x24
| __IO uint32_t SYSCFG_TypeDef::CFGR |
SYSCFG configuration registers, Address offset: 0x18
| __IO uint32_t SYSCFG_TypeDef::EXTICR |
SYSCFG external interrupt configuration registers, Address offset: 0x08-0x14
| __IO uint32_t SYSCFG_TypeDef::PKGR |
SYSCFG package register, Address offset: 0x124
| __IO uint32_t SYSCFG_TypeDef::PMCR |
SYSCFG peripheral mode configuration register, Address offset: 0x04
| __IO uint32_t SYSCFG_TypeDef::PWRCR |
PWR control register, Address offset: 0x2C
| uint32_t SYSCFG_TypeDef::RESERVED1 |
Reserved, Address offset: 0x00
| uint32_t SYSCFG_TypeDef::RESERVED2 |
Reserved, Address offset: 0x1C
| uint32_t SYSCFG_TypeDef::RESERVED3 |
Reserved, Address offset: 0x2C
Reserved, 0x30-0x120
| uint32_t SYSCFG_TypeDef::RESERVED4 |
Reserved, 0x34-0x120
Reserved, 0x128-0x2FC
| uint32_t SYSCFG_TypeDef::RESERVED5 |
| uint32_t SYSCFG_TypeDef::RESERVED6 |
Reserved, Address offset: 0x320-0x328
| __IO uint32_t SYSCFG_TypeDef::UR0 |
SYSCFG user register 0, Address offset: 0x300
| __IO uint32_t SYSCFG_TypeDef::UR1 |
SYSCFG user register 1, Address offset: 0x304
| __IO uint32_t SYSCFG_TypeDef::UR10 |
SYSCFG user register 10, Address offset: 0x328
| __IO uint32_t SYSCFG_TypeDef::UR11 |
SYSCFG user register 11, Address offset: 0x32C
| __IO uint32_t SYSCFG_TypeDef::UR12 |
SYSCFG user register 12, Address offset: 0x330
| __IO uint32_t SYSCFG_TypeDef::UR13 |
SYSCFG user register 13, Address offset: 0x334
| __IO uint32_t SYSCFG_TypeDef::UR14 |
SYSCFG user register 14, Address offset: 0x338
| __IO uint32_t SYSCFG_TypeDef::UR15 |
SYSCFG user register 15, Address offset: 0x33C
| __IO uint32_t SYSCFG_TypeDef::UR16 |
SYSCFG user register 16, Address offset: 0x340
| __IO uint32_t SYSCFG_TypeDef::UR17 |
SYSCFG user register 17, Address offset: 0x344
| __IO uint32_t SYSCFG_TypeDef::UR18 |
SYSCFG user register 18, Address offset: 0x348
| __IO uint32_t SYSCFG_TypeDef::UR2 |
SYSCFG user register 2, Address offset: 0x308
| __IO uint32_t SYSCFG_TypeDef::UR3 |
SYSCFG user register 3, Address offset: 0x30C
| __IO uint32_t SYSCFG_TypeDef::UR4 |
SYSCFG user register 4, Address offset: 0x310
| __IO uint32_t SYSCFG_TypeDef::UR5 |
SYSCFG user register 5, Address offset: 0x314
| __IO uint32_t SYSCFG_TypeDef::UR6 |
SYSCFG user register 6, Address offset: 0x318
| __IO uint32_t SYSCFG_TypeDef::UR7 |
SYSCFG user register 7, Address offset: 0x31C
| __IO uint32_t SYSCFG_TypeDef::UR8 |
SYSCFG user register 8, Address offset: 0x320
| __IO uint32_t SYSCFG_TypeDef::UR9 |
SYSCFG user register 9, Address offset: 0x324
