RTEMS 6.1
SWPMI_InitTypeDef Struct Reference
SWPMI Init Structure definition. More...
#include <stm32h7xx_hal_swpmi.h>
uint32_t VoltageClass
uint32_t BitRate
uint32_t TxBufferingMode
uint32_t RxBufferingMode
Field Documentation
◆ BitRate
uint32_t SWPMI_InitTypeDef::BitRate
Specifies the SWPMI Bitrate. This parameter must be a number between 0 and 255U. The Bitrate is computed using the following formula: SWPMI_freq = SWPMI_clk / (((BitRate) + 1) * 4)
◆ RxBufferingMode
uint32_t SWPMI_InitTypeDef::RxBufferingMode
Specifies the reception buffering mode. This parameter can be a value of SWPMI Rx Buffering Mode
◆ TxBufferingMode
uint32_t SWPMI_InitTypeDef::TxBufferingMode
Specifies the transmission buffering mode. This parameter can be a value of SWPMI Tx Buffering Mode
◆ VoltageClass
uint32_t SWPMI_InitTypeDef::VoltageClass
Specifies the SWP Voltage Class. This parameter can be a value of SWPMI Voltage Class
