RTEMS 6.1
SPI Configuration Structure definition. More...
#include <stm32h7xx_hal_spi.h>
uint32_t Mode
uint32_t Direction
uint32_t DataSize
uint32_t CLKPolarity
uint32_t CLKPhase
uint32_t NSS
uint32_t BaudRatePrescaler
uint32_t FirstBit
uint32_t TIMode
uint32_t CRCCalculation
uint32_t CRCPolynomial
uint32_t CRCLength
uint32_t NSSPMode
uint32_t NSSPolarity
uint32_t FifoThreshold
uint32_t TxCRCInitializationPattern
uint32_t RxCRCInitializationPattern
uint32_t MasterSSIdleness
uint32_t MasterInterDataIdleness
uint32_t MasterReceiverAutoSusp
uint32_t MasterKeepIOState
uint32_t IOSwap
Field Documentation
◆ BaudRatePrescaler
uint32_t SPI_InitTypeDef::BaudRatePrescaler
Specifies the Baud Rate prescaler value which will be used to configure the transmit and receive SCK clock. This parameter can be a value of SPI BaudRate Prescaler
Note
The communication clock is derived from the master clock. The slave clock does not need to be set.
◆ CLKPhase
uint32_t SPI_InitTypeDef::CLKPhase
Specifies the clock active edge for the bit capture. This parameter can be a value of SPI Clock Phase
◆ CLKPolarity
uint32_t SPI_InitTypeDef::CLKPolarity
Specifies the serial clock steady state. This parameter can be a value of SPI Clock Polarity
◆ CRCCalculation
uint32_t SPI_InitTypeDef::CRCCalculation
Specifies if the CRC calculation is enabled or not. This parameter can be a value of SPI CRC Calculation
◆ CRCLength
uint32_t SPI_InitTypeDef::CRCLength
Specifies the CRC Length used for the CRC calculation. This parameter can be a value of SPI CRC Length
◆ CRCPolynomial
uint32_t SPI_InitTypeDef::CRCPolynomial
Specifies the polynomial used for the CRC calculation. This parameter must be an odd number between Min_Data = 0 and Max_Data = 65535
◆ DataSize
uint32_t SPI_InitTypeDef::DataSize
Specifies the SPI data size. This parameter can be a value of SPI Data Size
◆ Direction
uint32_t SPI_InitTypeDef::Direction
Specifies the SPI bidirectional mode state. This parameter can be a value of SPI Direction Mode
◆ FifoThreshold
uint32_t SPI_InitTypeDef::FifoThreshold
Specifies the FIFO threshold level. This parameter can be a value of SPI Fifo Threshold
◆ FirstBit
uint32_t SPI_InitTypeDef::FirstBit
Specifies whether data transfers start from MSB or LSB bit. This parameter can be a value of SPI MSB LSB Transmission
◆ IOSwap
uint32_t SPI_InitTypeDef::IOSwap
Invert MISO/MOSI alternate functions This parameter can be a value of Control SPI IO Swap
◆ MasterInterDataIdleness
uint32_t SPI_InitTypeDef::MasterInterDataIdleness
Specifies minimum time delay (expressed in SPI clock cycles periods) inserted between two consecutive data frames in master mode. This parameter can be a value of SPI Master Inter-Data Idleness
◆ MasterKeepIOState
uint32_t SPI_InitTypeDef::MasterKeepIOState
Control of Alternate function GPIOs state This parameter can be a value of Keep IO State
◆ MasterReceiverAutoSusp
uint32_t SPI_InitTypeDef::MasterReceiverAutoSusp
Control continuous SPI transfer in master receiver mode and automatic management in order to avoid overrun condition. This parameter can be a value of SPI Master Receiver AutoSuspend
◆ MasterSSIdleness
uint32_t SPI_InitTypeDef::MasterSSIdleness
Specifies an extra delay, expressed in number of SPI clock cycle periods, inserted additionally between active edge of SS and first data transaction start in master mode. This parameter can be a value of SPI Master SS Idleness
◆ Mode
uint32_t SPI_InitTypeDef::Mode
Specifies the SPI operating mode. This parameter can be a value of SPI Mode
◆ NSS
uint32_t SPI_InitTypeDef::NSS
Specifies whether the NSS signal is managed by hardware (NSS pin) or by software using the SSI bit. This parameter can be a value of SPI Slave Select Management
◆ NSSPMode
uint32_t SPI_InitTypeDef::NSSPMode
Specifies whether the NSSP signal is enabled or not . This parameter can be a value of SPI NSS Pulse Mode This mode is activated by the SSOM bit in the SPIx_CR2 register and it takes effect only if the SPI interface is configured as Motorola SPI master (FRF=0).
◆ NSSPolarity
uint32_t SPI_InitTypeDef::NSSPolarity
Specifies which level of SS input/output external signal (present on SS pin) is considered as active one. This parameter can be a value of SPI NSS Polarity
◆ RxCRCInitializationPattern
uint32_t SPI_InitTypeDef::RxCRCInitializationPattern
Specifies the receiver CRC initialization Pattern used for the CRC calculation. This parameter can be a value of SPI CRC Calculation Initialization Pattern
◆ TIMode
uint32_t SPI_InitTypeDef::TIMode
Specifies if the TI mode is enabled or not. This parameter can be a value of SPI TI Mode
◆ TxCRCInitializationPattern
uint32_t SPI_InitTypeDef::TxCRCInitializationPattern
Specifies the transmitter CRC initialization Pattern used for the CRC calculation. This parameter can be a value of SPI CRC Calculation Initialization Pattern
