RTEMS 6.1
uint32_t Timing
uint32_t AnalogFilter
uint32_t OwnAddress1
uint32_t AddressingMode
uint32_t DualAddressMode
uint32_t OwnAddress2
uint32_t OwnAddress2Masks
uint32_t GeneralCallMode
uint32_t NoStretchMode
uint32_t PacketErrorCheckMode
uint32_t PeripheralMode
uint32_t SMBusTimeout
Field Documentation
◆ AddressingMode
uint32_t SMBUS_InitTypeDef::AddressingMode
Specifies if 7-bit or 10-bit addressing mode for master is selected. This parameter can be a value of SMBUS addressing mode
◆ AnalogFilter
uint32_t SMBUS_InitTypeDef::AnalogFilter
Specifies if Analog Filter is enable or not. This parameter can be a value of SMBUS Analog Filter
◆ DualAddressMode
uint32_t SMBUS_InitTypeDef::DualAddressMode
Specifies if dual addressing mode is selected. This parameter can be a value of SMBUS dual addressing mode
◆ GeneralCallMode
uint32_t SMBUS_InitTypeDef::GeneralCallMode
Specifies if general call mode is selected. This parameter can be a value of SMBUS general call addressing mode.
◆ NoStretchMode
uint32_t SMBUS_InitTypeDef::NoStretchMode
Specifies if nostretch mode is selected. This parameter can be a value of SMBUS nostretch mode
◆ OwnAddress1
uint32_t SMBUS_InitTypeDef::OwnAddress1
Specifies the first device own address. This parameter can be a 7-bit or 10-bit address.
◆ OwnAddress2
uint32_t SMBUS_InitTypeDef::OwnAddress2
Specifies the second device own address if dual addressing mode is selected This parameter can be a 7-bit address.
◆ OwnAddress2Masks
uint32_t SMBUS_InitTypeDef::OwnAddress2Masks
Specifies the acknowledge mask address second device own address if dual addressing mode is selected This parameter can be a value of SMBUS ownaddress2 masks.
◆ PacketErrorCheckMode
uint32_t SMBUS_InitTypeDef::PacketErrorCheckMode
Specifies if Packet Error Check mode is selected. This parameter can be a value of SMBUS packet error check mode
◆ PeripheralMode
uint32_t SMBUS_InitTypeDef::PeripheralMode
Specifies which mode of Periphal is selected. This parameter can be a value of SMBUS peripheral mode
◆ SMBusTimeout
uint32_t SMBUS_InitTypeDef::SMBusTimeout
Specifies the content of the 32 Bits SMBUS_TIMEOUT_register value. (Enable bits and different timeout values) This parameter calculated by referring to SMBUS initialization section in Reference manual
◆ Timing
uint32_t SMBUS_InitTypeDef::Timing
Specifies the SMBUS_TIMINGR_register value. This parameter calculated by referring to SMBUS initialization section in Reference manual
