RTEMS 6.1
Test context for spec:/rtems/timer/val/timer test case. More...
Data Fields | |
| rtems_id | timer_ids [TEST_MAXIMUM_TIMERS] |
| This member contains the timer identifiers. | |
| Atomic_Uint | counter |
| This member contains the counter. | |
| unsigned int | counter_snapshots [TEST_MAXIMUM_TIMERS] |
| This member contains the timer counter snapshots. | |
