RTEMS 6.1
Test context for spec:/rtems/timer/req/reset test case. More...
Data Fields | |
| rtems_id | timer_id |
| This member contains a valid id of a timer. | |
| rtems_id | id_param |
This member specifies the id parameter for the action. | |
| rtems_status_code | status |
| This member contains the returned status code of the action. | |
| void * | data_a |
| This member contains the user data for Timer Service Routine "A". | |
| void * | data_b |
| This member contains the user data for Timer Service Routine "B". | |
| int | invocations_a |
| This member contains the counter for invocations of Timer Service Routine "A". | |
| int | invocations_b |
| This member contains the counter for invocations of Timer Service Routine "B". | |
| Scheduling_Ticks | ticks_till_fire |
| This member contains the number of ticks needed to fire the Timer Service Routine. | |
| void ** | routine_user_data |
| This member identifier the user data given to the Timer Service Routine when called. It either the address of member data_a or data_b. | |
| void ** | scheduled_user_data |
| This member contains a reference to the user data to be used in the next call to the Timer Service Routine. | |
| int | scheduled_invocations_a |
| This member contains 1 if the Timer Service Routine "A" has been scheduled otherwise 0. | |
| int | scheduled_invocations_b |
| This member contains 1 if the Timer Service Routine "B" has been scheduled otherwise 0. | |
| Scheduling_Ticks | scheduled_ticks_till_fire |
| This member specifies the number of ticks till the scheduled Timer Service Routine should fire. | |
| PreConditionContext | pre_cond_contex |
| This member specifies which pre-condition context (none, interrupt context, server context) must be created before the rtems_timer_reset() action gets executed. | |
| Timer_Classes | pre_class |
| This member stores internal clock and context settings of the timer before the execution of the test action. | |
| Timer_States | pre_state |
| This member stores the state of the timer before the execution of the test action. | |
| Timer_States | post_state |
| This member stores the state of the timer after the execution of the test action. | |
| Timer_Scheduling_Data | pre_scheduling_data |
| This member stores the scheduling data of the timer before the execution of the test action. | |
| Timer_Scheduling_Data | post_scheduling_data |
| This member stores the scheduling data of the timer after the execution of the test action. | |
| struct { | |
| size_t pcs [4] | |
| This member defines the pre-condition states for the next action. | |
| bool in_action_loop | |
| If this member is true, then the test action loop is executed. | |
| size_t index | |
| This member contains the next transition map index. | |
| RtemsTimerReqReset_Entry entry | |
| This member contains the current transition map entry. | |
| bool skip | |
| If this member is true, then the current transition variant should be skipped. | |
| } | Map |
