RTEMS 6.1
Test context for spec:/rtems/task/req/restart test case. More...
Data Fields | |
| T_scheduler_log_10 | scheduler_log |
| This member provides the scheduler operation records. | |
| jmp_buf | thread_dispatch_context |
| This member provides a jump context to resume a thread dispatch. | |
| WrapThreadQueueContext | wrap_tq_ctx |
| This member provides the context to wrap thread queue operations. | |
| rtems_id | scheduler_id |
| This member contains the identifier of the runner scheduler. | |
| rtems_id | runner_id |
| This member contains the identifier of the runner task. | |
| rtems_id | mutex_id |
| This member contains the identifier of the mutex. | |
| rtems_event_set | events |
| This member provides an event set used to set up the blocking conditions of the task to restart. | |
| rtems_id | worker_id |
| This member contains the identifier of the worker task. | |
| rtems_tcb * | worker_tcb |
| This member references the TCB of the worker task. | |
| States_Control | worker_state |
| This member contains the worker state at the end of the rtems_task_restart() call. | |
| Thread_Life_state | worker_life_state |
| This member contains the worker thread life state at the end of the rtems_task_restart() call. | |
| rtems_id | deleter_id |
| This member contains the identifier of the deleter task. | |
| rtems_tcb * | deleter_tcb |
| This member references the TCB of the deleter task. | |
| rtems_id | extension_id |
| This member contains the identifier of the test user extensions. | |
| ExtensionCalls | calls |
| This member contains extension calls. | |
| ExtensionCalls | calls_after_restart |
| This member contains extension calls after the rtems_task_restart() call. | |
| rtems_task_argument | actual_argument |
| This member contains the actual argument passed to the entry point. | |
| uint32_t | restart_counter |
| This member contains the restart counter. | |
| bool | dormant |
| If this member is true, then the worker shall be dormant before the rtems_task_restart() call. | |
| bool | suspended |
| If this member is true, then the worker shall be suspended before the rtems_task_restart() call. | |
| bool | protected |
| If this member is true, then the thread life of the worker shall be protected before the rtems_task_restart() call. | |
| bool | restarting |
| If this member is true, then the worker shall be restarting before the rtems_task_restart() call. | |
| bool | terminating |
| If this member is true, then the worker shall be terminating before the rtems_task_restart() call. | |
| bool | interrupt |
| If this member is true, then the rtems_task_restart() shall be called from within interrupt context. | |
| bool | nested_request |
| If this member is true, then the rtems_task_restart() shall be called during another rtems_task_restart() call with the same task as a nested request. | |
| bool | blocked |
| If this member is true, then the worker shall be blocked before the rtems_task_restart() call. | |
| bool | enqueued |
| If this member is true, then the worker shall be enqueued on a wait queue before the rtems_task_restart() call. | |
| bool | timer_active |
| If this member is true, then the timer of the worker shall be active before the rtems_task_restart() call. | |
| bool | real_priority_is_initial |
| If this member is true, then the real priority of the worker shall be equal to its initial priority before the rtems_task_restart() call. | |
| bool | dispatch_disabled |
| If this member is true, then thread dispatching is disabled by the worker task before the rtems_task_restart() call. | |
| bool | delete_worker_expected |
| If this member is true, then it is expected to delete the worker. | |
| rtems_status_code | status |
| This member contains the return value of the rtems_task_restart() call. | |
| rtems_id | id |
This member specifies if the id parameter value. | |
| struct { | |
| size_t pci [11] | |
| This member defines the pre-condition indices for the next action. | |
| size_t pcs [11] | |
| This member defines the pre-condition states for the next action. | |
| bool in_action_loop | |
| If this member is true, then the test action loop is executed. | |
| size_t index | |
| This member contains the next transition map index. | |
| RtemsTaskReqRestart_Entry entry | |
| This member contains the current transition map entry. | |
| bool skip | |
| If this member is true, then the current transition variant should be skipped. | |
| } | Map |
