RTEMS 6.1
Test context for spec:/rtems/status/req/is-equal test case. More...
bool result
 This member contains the return value of the rtems_are_statuses_equal() call.
rtems_status_code status_0
 This member specifies if the left_status_code parameter value.
rtems_status_code status_1
 This member specifies if the right_status_code parameter value.
struct {
   size_t   pcs [1]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsStatusReqIsEqual_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
