RTEMS 6.1
Test context for spec:/rtems/scheduler/req/get-processor-set test case. More...
rtems_id scheduler_id
 This member contains the identifier of a scheduler.
cpu_set_t cpuset_value
 This member provides the object referenced by the cpusetsize parameter.
rtems_status_code status
 This member contains the return value of the rtems_scheduler_get_processor_set() call.
rtems_id id
 This member specifies if the scheduler_id parameter value.
size_t cpusetsize
 This member specifies if the cpusetsize parameter value.
cpu_set_t * cpuset
 This member specifies if the cpuset parameter value.
struct {
   size_t   pcs [3]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsSchedulerReqGetProcessorSet_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
