RTEMS 6.1
Test context for spec:/rtems/ratemon/req/period test case. More...
Data Fields | |
| rtems_id | period_id |
| This member contains a valid identifier of a period. | |
| rtems_rate_monotonic_period_status | period_status |
| This member is used to receive the rtems_rate_monotonic_period_status after the action. | |
| rtems_id | id_param |
This member specifies the id parameter for the action. | |
| rtems_interval | length_param |
This member specifies the length parameter for the action. | |
| rtems_status_code | status |
| This member contains the returned status code of the action. | |
| uint32_t(* | do_action )(void *ctx, void(*todo)(void *ctx_arg)) |
| This member contains the pointer to the function which executes the action. | |
| void(* | worker_todo )(void *ctx) |
This member serves to pass the pointer to the function which the work owner task shall execute from function OwnerDoWork to function WorkerTask. | |
| rtems_id | task_id |
| This member contains the owner task identifier of the owner task. | |
| rtems_id | worker_id |
| This member contains the owner task identifier of the worker task (which is not the owner task). | |
| rtems_id | original_priority |
| This member contains a backup of the task priority before the execution of this test. | |
| uint32_t | postponed_jobs_count |
| This member contains the number of postponed jobs before the action. | |
| rtems_rate_monotonic_period_states | previous_state |
| This member contains the state before the action. | |
| uint32_t | test_duration |
| This member contains the number of clock ticks passed since the test started. | |
| uint32_t | test_duration_till_action |
| This member contains the number of clock ticks passed since the test started till (before) the rtems_rate_monotonic_period() action is invoked. | |
| uint32_t | period_calls |
| This member contains the number of times the rtems_rate_monotonic_period() function returned since the test started. | |
| uint32_t | action_duration |
| This member contains the number of clock ticks which passed in the action till the rtems_rate_monotonic_period() function returned. | |
| struct { | |
| size_t pci [6] | |
| This member defines the pre-condition indices for the next action. | |
| size_t pcs [6] | |
| This member defines the pre-condition states for the next action. | |
| bool in_action_loop | |
| If this member is true, then the test action loop is executed. | |
| size_t index | |
| This member contains the next transition map index. | |
| RtemsRatemonReqPeriod_Entry entry | |
| This member contains the current transition map entry. | |
| bool skip | |
| If this member is true, then the current transition variant should be skipped. | |
| } | Map |
| uint32_t(* RtemsRatemonReqPeriod_Context::do_action) (void *ctx, void(*todo)(void *ctx_arg)) |
The action is either executed by the owner task or by the worker task depending on the function pointer used here. ctx_arg must be a pointer to this context structure.
