RTEMS 6.1
Test context for spec:/rtems/part/req/return-buffer test case. More...
rtems_status_code status
rtems_id id
rtems_id id_value
void * buffer
void * buffer_in_use
struct {
   size_t   pcs [2]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsPartReqReturnBuffer_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
