RTEMS 6.1
Test context for spec:/rtems/io/req/putc test case. More...
Data Fields | |
| int | output [2] |
| This member contains the character output. | |
| size_t | output_count |
| This member contains the character output count. | |
| char | character |
This member specifies if the c parameter value. | |
| struct { | |
| size_t pcs [1] | |
| This member defines the pre-condition states for the next action. | |
| bool in_action_loop | |
| If this member is true, then the test action loop is executed. | |
| size_t index | |
| This member contains the next transition map index. | |
| RtemsIoReqPutc_Entry entry | |
| This member contains the current transition map entry. | |
| bool skip | |
| If this member is true, then the current transition variant should be skipped. | |
| } | Map |
