RTEMS 6.1
Test context for spec:/rtems/clock/req/get-tod test case. More...
Data Fields | |
| rtems_status_code | set_tod_status |
| rtems_time_of_day | set_tod_value |
| rtems_time_of_day * | get_tod_ref |
| rtems_time_of_day | get_tod_value |
| rtems_status_code | get_tod_status |
| bool | isDef |
| struct { | |
| size_t pcs [2] | |
| This member defines the pre-condition states for the next action. | |
| bool in_action_loop | |
| If this member is true, then the test action loop is executed. | |
| size_t index | |
| This member contains the next transition map index. | |
| RtemsClockReqGetTod_Entry entry | |
| This member contains the current transition map entry. | |
| bool skip | |
| If this member is true, then the current transition variant should be skipped. | |
| } | Map |
