RTEMS 6.1
Rate_monotonic_Statistics Struct Reference
#include <ratemondata.h>
uint32_t count
uint32_t missed_count
Timestamp_Control min_cpu_time
Timestamp_Control max_cpu_time
Timestamp_Control total_cpu_time
Timestamp_Control min_wall_time
Timestamp_Control max_wall_time
Timestamp_Control total_wall_time
The following defines the INTERNAL data structure that has the statistics kept on each period instance.
Field Documentation
◆ count
uint32_t Rate_monotonic_Statistics::count
This field contains the number of periods executed.
◆ max_cpu_time
Timestamp_Control Rate_monotonic_Statistics::max_cpu_time
This field contains the highest amount of CPU time used in a period.
◆ max_wall_time
Timestamp_Control Rate_monotonic_Statistics::max_wall_time
This field contains the highest amount of wall time used in a period.
◆ min_cpu_time
Timestamp_Control Rate_monotonic_Statistics::min_cpu_time
This field contains the least amount of CPU time used in a period.
◆ min_wall_time
Timestamp_Control Rate_monotonic_Statistics::min_wall_time
This field contains the least amount of wall time used in a period.
◆ missed_count
uint32_t Rate_monotonic_Statistics::missed_count
This field contains the number of periods missed.
◆ total_cpu_time
Timestamp_Control Rate_monotonic_Statistics::total_cpu_time
This field contains the total amount of wall time used in a period.
◆ total_wall_time
Timestamp_Control Rate_monotonic_Statistics::total_wall_time
This field contains the total amount of CPU time used in a period.
