RTEMS 6.1
Real-Time Clock. More...
#include <stm32h723xx.h>
Data Fields | |
| __IO uint32_t | TR |
| __IO uint32_t | DR |
| __IO uint32_t | CR |
| __IO uint32_t | ISR |
| __IO uint32_t | PRER |
| __IO uint32_t | WUTR |
| uint32_t | RESERVED |
| __IO uint32_t | ALRMAR |
| __IO uint32_t | ALRMBR |
| __IO uint32_t | WPR |
| __IO uint32_t | SSR |
| __IO uint32_t | SHIFTR |
| __IO uint32_t | TSTR |
| __IO uint32_t | TSDR |
| __IO uint32_t | TSSSR |
| __IO uint32_t | CALR |
| __IO uint32_t | TAMPCR |
| __IO uint32_t | ALRMASSR |
| __IO uint32_t | ALRMBSSR |
| __IO uint32_t | OR |
| __IO uint32_t | BKP0R |
| __IO uint32_t | BKP1R |
| __IO uint32_t | BKP2R |
| __IO uint32_t | BKP3R |
| __IO uint32_t | BKP4R |
| __IO uint32_t | BKP5R |
| __IO uint32_t | BKP6R |
| __IO uint32_t | BKP7R |
| __IO uint32_t | BKP8R |
| __IO uint32_t | BKP9R |
| __IO uint32_t | BKP10R |
| __IO uint32_t | BKP11R |
| __IO uint32_t | BKP12R |
| __IO uint32_t | BKP13R |
| __IO uint32_t | BKP14R |
| __IO uint32_t | BKP15R |
| __IO uint32_t | BKP16R |
| __IO uint32_t | BKP17R |
| __IO uint32_t | BKP18R |
| __IO uint32_t | BKP19R |
| __IO uint32_t | BKP20R |
| __IO uint32_t | BKP21R |
| __IO uint32_t | BKP22R |
| __IO uint32_t | BKP23R |
| __IO uint32_t | BKP24R |
| __IO uint32_t | BKP25R |
| __IO uint32_t | BKP26R |
| __IO uint32_t | BKP27R |
| __IO uint32_t | BKP28R |
| __IO uint32_t | BKP29R |
| __IO uint32_t | BKP30R |
| __IO uint32_t | BKP31R |
| __IO uint32_t | ICSR |
| uint32_t | RESERVED0 |
| uint32_t | RESERVED1 |
| uint32_t | RESERVED2 |
| __IO uint32_t | SR |
| __IO uint32_t | MISR |
| uint32_t | RESERVED3 |
| __IO uint32_t | SCR |
| __IO uint32_t | CFGR |
Real-Time Clock.
| __IO uint32_t RTC_TypeDef::ALRMAR |
RTC alarm A register, Address offset: 0x1C
RTC alarm A register, Address offset: 0x40
| __IO uint32_t RTC_TypeDef::ALRMASSR |
RTC alarm A sub second register, Address offset: 0x44
| __IO uint32_t RTC_TypeDef::ALRMBR |
RTC alarm B register, Address offset: 0x20
RTC alarm B register, Address offset: 0x48
| __IO uint32_t RTC_TypeDef::ALRMBSSR |
RTC alarm B sub second register, Address offset: 0x48
RTC alarm B sub second register, Address offset: 0x4C
| __IO uint32_t RTC_TypeDef::BKP0R |
RTC backup register 0, Address offset: 0x50
| __IO uint32_t RTC_TypeDef::BKP10R |
RTC backup register 10, Address offset: 0x78
| __IO uint32_t RTC_TypeDef::BKP11R |
RTC backup register 11, Address offset: 0x7C
| __IO uint32_t RTC_TypeDef::BKP12R |
RTC backup register 12, Address offset: 0x80
| __IO uint32_t RTC_TypeDef::BKP13R |
RTC backup register 13, Address offset: 0x84
| __IO uint32_t RTC_TypeDef::BKP14R |
RTC backup register 14, Address offset: 0x88
| __IO uint32_t RTC_TypeDef::BKP15R |
RTC backup register 15, Address offset: 0x8C
| __IO uint32_t RTC_TypeDef::BKP16R |
RTC backup register 16, Address offset: 0x90
| __IO uint32_t RTC_TypeDef::BKP17R |
RTC backup register 17, Address offset: 0x94
| __IO uint32_t RTC_TypeDef::BKP18R |
RTC backup register 18, Address offset: 0x98
| __IO uint32_t RTC_TypeDef::BKP19R |
RTC backup register 19, Address offset: 0x9C
| __IO uint32_t RTC_TypeDef::BKP1R |
RTC backup register 1, Address offset: 0x54
| __IO uint32_t RTC_TypeDef::BKP20R |
RTC backup register 20, Address offset: 0xA0
| __IO uint32_t RTC_TypeDef::BKP21R |
RTC backup register 21, Address offset: 0xA4
| __IO uint32_t RTC_TypeDef::BKP22R |
RTC backup register 22, Address offset: 0xA8
| __IO uint32_t RTC_TypeDef::BKP23R |
RTC backup register 23, Address offset: 0xAC
| __IO uint32_t RTC_TypeDef::BKP24R |
RTC backup register 24, Address offset: 0xB0
| __IO uint32_t RTC_TypeDef::BKP25R |
RTC backup register 25, Address offset: 0xB4
| __IO uint32_t RTC_TypeDef::BKP26R |
RTC backup register 26, Address offset: 0xB8
| __IO uint32_t RTC_TypeDef::BKP27R |
RTC backup register 27, Address offset: 0xBC
| __IO uint32_t RTC_TypeDef::BKP28R |
RTC backup register 28, Address offset: 0xC0
| __IO uint32_t RTC_TypeDef::BKP29R |
RTC backup register 29, Address offset: 0xC4
| __IO uint32_t RTC_TypeDef::BKP2R |
RTC backup register 2, Address offset: 0x58
| __IO uint32_t RTC_TypeDef::BKP30R |
RTC backup register 30, Address offset: 0xC8
| __IO uint32_t RTC_TypeDef::BKP31R |
RTC backup register 31, Address offset: 0xCC
| __IO uint32_t RTC_TypeDef::BKP3R |
RTC backup register 3, Address offset: 0x5C
| __IO uint32_t RTC_TypeDef::BKP4R |
RTC backup register 4, Address offset: 0x60
| __IO uint32_t RTC_TypeDef::BKP5R |
RTC backup register 5, Address offset: 0x64
| __IO uint32_t RTC_TypeDef::BKP6R |
RTC backup register 6, Address offset: 0x68
| __IO uint32_t RTC_TypeDef::BKP7R |
RTC backup register 7, Address offset: 0x6C
| __IO uint32_t RTC_TypeDef::BKP8R |
RTC backup register 8, Address offset: 0x70
| __IO uint32_t RTC_TypeDef::BKP9R |
RTC backup register 9, Address offset: 0x74
| __IO uint32_t RTC_TypeDef::CALR |
RTC calibration register, Address offset: 0x3C
RTC calibration register, Address offset: 0x28
| __IO uint32_t RTC_TypeDef::CFGR |
RTC configuration register, Address offset: 0x60
| __IO uint32_t RTC_TypeDef::CR |
RTC control register, Address offset: 0x08
RTC control register, Address offset: 0x18
| __IO uint32_t RTC_TypeDef::DR |
RTC date register, Address offset: 0x04
| __IO uint32_t RTC_TypeDef::ICSR |
RTC initialization control and status register, Address offset: 0x0C
| __IO uint32_t RTC_TypeDef::ISR |
RTC initialization and status register, Address offset: 0x0C
| __IO uint32_t RTC_TypeDef::MISR |
RTC masked interrupt status register, Address offset: 0x54
| __IO uint32_t RTC_TypeDef::OR |
RTC option register, Address offset: 0x4C
| __IO uint32_t RTC_TypeDef::PRER |
RTC prescaler register, Address offset: 0x10
| uint32_t RTC_TypeDef::RESERVED |
Reserved, Address offset: 0x18
| uint32_t RTC_TypeDef::RESERVED0 |
Reserved, Address offset: 0x1C
| uint32_t RTC_TypeDef::RESERVED1 |
Reserved, Address offset: 0x20
| uint32_t RTC_TypeDef::RESERVED2 |
Reserved, Address offset: 0x3C
| uint32_t RTC_TypeDef::RESERVED3 |
Reserved, Address offset: 0x58
| __IO uint32_t RTC_TypeDef::SCR |
RTC status Clear register, Address offset: 0x5C
| __IO uint32_t RTC_TypeDef::SHIFTR |
RTC shift control register, Address offset: 0x2C
| __IO uint32_t RTC_TypeDef::SR |
RTC Status register, Address offset: 0x50
| __IO uint32_t RTC_TypeDef::SSR |
RTC sub second register, Address offset: 0x28
RTC sub second register, Address offset: 0x08
| __IO uint32_t RTC_TypeDef::TAMPCR |
RTC tamper configuration register, Address offset: 0x40
| __IO uint32_t RTC_TypeDef::TR |
RTC time register, Address offset: 0x00
| __IO uint32_t RTC_TypeDef::TSDR |
RTC time stamp date register, Address offset: 0x34
| __IO uint32_t RTC_TypeDef::TSSSR |
RTC time-stamp sub second register, Address offset: 0x38
| __IO uint32_t RTC_TypeDef::TSTR |
RTC time stamp time register, Address offset: 0x30
| __IO uint32_t RTC_TypeDef::WPR |
RTC write protection register, Address offset: 0x24
| __IO uint32_t RTC_TypeDef::WUTR |
RTC wakeup timer register, Address offset: 0x14
