RTEMS 6.1
uint32_t Tamper
uint32_t Interrupt
uint32_t Trigger
uint32_t NoErase
uint32_t MaskFlag
uint32_t Filter
uint32_t SamplingFrequency
uint32_t PrechargeDuration
uint32_t TamperPullUp
uint32_t TimeStampOnTamperDetection
Field Documentation
◆ Filter
uint32_t RTC_TamperTypeDef::Filter
Specifies the TAMP Filter Tamper. This parameter can be a value of RTC Tamper Filter Definitions
◆ Interrupt
uint32_t RTC_TamperTypeDef::Interrupt
Specifies the Tamper Interrupt. This parameter can be a value of RTC Tamper Interrupts Definitions
◆ MaskFlag
uint32_t RTC_TamperTypeDef::MaskFlag
Specifies the Tamper Flag masking. This parameter can be a value of RTC Tamper Mask Flag Definitions
◆ NoErase
uint32_t RTC_TamperTypeDef::NoErase
Specifies the Tamper no erase mode. This parameter can be a value of RTC Tamper EraseBackUp Definitions
◆ PrechargeDuration
uint32_t RTC_TamperTypeDef::PrechargeDuration
Specifies the Precharge Duration . This parameter can be a value of RTC Tamper Pin Precharge Duration Definitions
◆ SamplingFrequency
uint32_t RTC_TamperTypeDef::SamplingFrequency
Specifies the sampling frequency. This parameter can be a value of RTC Tamper Sampling Frequencies Definitions
◆ Tamper
uint32_t RTC_TamperTypeDef::Tamper
Specifies the Tamper Pin. This parameter can be a value of RTC Tamper Pins Definitions
◆ TamperPullUp
uint32_t RTC_TamperTypeDef::TamperPullUp
Specifies the Tamper PullUp . This parameter can be a value of RTC Tamper Pull Up Definitions
◆ TimeStampOnTamperDetection
uint32_t RTC_TamperTypeDef::TimeStampOnTamperDetection
Specifies the TimeStampOnTamperDetection. This parameter can be a value of RTC Tamper TimeStamp On Tamper Detection Definitions
◆ Trigger
uint32_t RTC_TamperTypeDef::Trigger
Specifies the Tamper Trigger. This parameter can be a value of RTC Tamper Triggers Definitions
