RTEMS 6.1
RTC_InitTypeDef Struct Reference
RTC Configuration Structure definition. More...
#include <stm32h7xx_hal_rtc.h>
uint32_t HourFormat
uint32_t AsynchPrediv
uint32_t SynchPrediv
uint32_t OutPut
uint32_t OutPutRemap
uint32_t OutPutPolarity
uint32_t OutPutType
Field Documentation
◆ AsynchPrediv
uint32_t RTC_InitTypeDef::AsynchPrediv
Specifies the RTC Asynchronous Predivider value. This parameter must be a number between Min_Data = 0x00 and Max_Data = 0x7F
◆ HourFormat
uint32_t RTC_InitTypeDef::HourFormat
Specifies the RTC Hour Format. This parameter can be a value of RTC Hour Formats Definitions
◆ OutPut
uint32_t RTC_InitTypeDef::OutPut
Specifies which signal will be routed to the RTC output. This parameter can be a value of RTC Output Selection Definitions
◆ OutPutPolarity
uint32_t RTC_InitTypeDef::OutPutPolarity
Specifies the polarity of the output signal. This parameter can be a value of RTC Output Polarity Definitions
◆ OutPutRemap
uint32_t RTC_InitTypeDef::OutPutRemap
Specifies the remap for RTC output. This parameter can be a value of RTC Output ALARM OUT Remap
◆ OutPutType
uint32_t RTC_InitTypeDef::OutPutType
Specifies the RTC Output Pin mode. This parameter can be a value of RTC Output Type ALARM OUT
◆ SynchPrediv
uint32_t RTC_InitTypeDef::SynchPrediv
Specifies the RTC Synchronous Predivider value. This parameter must be a number between Min_Data = 0x00 and Max_Data = 0x7FFF
