RTEMS 6.1
RTC_AlarmTypeDef Struct Reference
RTC Alarm structure definition. More...
#include <stm32h7xx_hal_rtc.h>
RTC_TimeTypeDef AlarmTime
uint32_t AlarmMask
uint32_t AlarmSubSecondMask
uint32_t AlarmDateWeekDaySel
uint8_t AlarmDateWeekDay
uint32_t Alarm
Field Documentation
◆ Alarm
uint32_t RTC_AlarmTypeDef::Alarm
Specifies the alarm . This parameter can be a value of RTC Alarms Definitions
◆ AlarmDateWeekDay
uint8_t RTC_AlarmTypeDef::AlarmDateWeekDay
Specifies the RTC Alarm Date/WeekDay. If the Alarm Date is selected, this parameter must be set to a value in the 1-31 range. If the Alarm WeekDay is selected, this parameter can be a value of RTC WeekDay Definitions
◆ AlarmDateWeekDaySel
uint32_t RTC_AlarmTypeDef::AlarmDateWeekDaySel
Specifies the RTC Alarm is on Date or WeekDay. This parameter can be a value of RTC Alarm Date WeekDay Definitions
◆ AlarmMask
uint32_t RTC_AlarmTypeDef::AlarmMask
Specifies the RTC Alarm Masks. This parameter can be a value of RTC Alarm Mask Definitions
◆ AlarmSubSecondMask
uint32_t RTC_AlarmTypeDef::AlarmSubSecondMask
Specifies the RTC Alarm SubSeconds Masks. This parameter can be a value of RTC Alarm Sub Seconds Masks Definitions
◆ AlarmTime
RTC_TimeTypeDef RTC_AlarmTypeDef::AlarmTime
Specifies the RTC Alarm Time members
